Unable to Start a virtual controller/unpack Pack & Go succesfully
zl522
My RobotStudio suddenly can't launch any virtual controller (which previously worked fine); I'm using RobotWare version 6.10.
I've attempted the following measures without success:
- installing the latest RobotStudio
- creating a new VC, which also failed to start
- uninstalling recent Windows updates
- turning off the Windows Defender firewall
- and repacking the previous Pack & Go.
While I try unpacking a Pack & Go file, the window displays
"Failed to restore backup from %VC name%. Restore failed for one or more
controllers in the Pack & Go file. "
"Please try to restore the backup
manually, or unpack again using a RobotWare version that matches the
original."
RobotStudio .NET exception: C0040403: No response from
controller. Netscan timeout
Base exception: RobApiException C0040403: No response from controller. Netscan timeout at RobotStudio.Services.RobApi.RobVcFactory.<>c__DisplayClass4_0.<<StartVC>b__0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at RobotStudio.Services.RobApi.RobVcFactory.<StartVC>d__4.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at RobotStudio.Services.Systems.SystemHelper.<RestoreBackup>d__8.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at RobotStudio.Services.Systems.SystemHelper.<RestoreBackup>d__8.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at ABBInternal.StationManagement.PackAndGoService.<RestoreBackup>d__22.MoveNext()
While I tried to launch a previously working project, an error message appeared stating,
"There was a problem when starting the virtual controller.
No response from controller."
Post edited by zl522 on
