Trap conditions
How to activate the trap conditions in robot running time DO signal cutoff means how to stop the robot
A little more explanation would be appreciated but here is an example of what I think you are referring to.
VAR intnum sig1int;
PROC main ()
IDelete sig1int;
CONNECT sig1int WITH trap_stop_at_once;
ISignalDO do1, 0, sig1int;
!Do stuff here.
!Do stuff here
TRAP trap_stop_at_once
stop;
ENDTRAP
revans said:A little more explanation would be appreciated but here is an example of what I think you are referring to.
VAR intnum sig1int;
PROC main ()
IDelete sig1int;
!Do stuff here.
!Do stuff here
stop;
ENDTRAP
Hi ...Use ISleep and IWatch to start and stop trap monitoring.Just Complementing...TRAP trap_stop_at_once ISleep sig1int ! Avoids recursion while executing the trap StopMove; ! Wait for UP Signal WaitUntil do1=1; StartMove; IWatch sig1int ENDTRAPGood Job0
- 858 RAPID Programming
