2 robots mounted on a single track in robot studio.
I am trying to create a station in which 2 robots are mounted on a single irbt 2005 track. Firstly I am not able to import this track with 2 robot carriages as shown in the product intro pdf of IRBT 2005 track. So, I created my own mechanism with 2 linear moving plates and added two IRB 2600 ID robots on it. But I am not able to create virtual controller for this station. So, I request some one to guide me as to how to create a station where I can mount 2 IRB 2600 ID robots on a single linear track. Robots are going to work in multimove independent.
Thanks for time and help.
  • https://youtu.be/pJeok4rkrns?si=_O6wlIDginWB6aX_
    The above video should show what I believe you are wanting to do or at least get you on the right track. Not I am using robotware 6.15.06. I have not had a chance to verify that multimove is available in omnicore robots yet. All of the robotware 6.xx options should work though.
    Thanks sir. You created the video just to solve my problem. Thanks for this kind of support. Thanks kind sir.
