Why is speed limit check point not working?
Gilad
I am trying to program a robot to take a specified amount of time going from point to point, but I wanted to decrease the maximum speed so that it doesn't choose to run at the max speed of the robot.
The ideal code would look like this:
SpeedLimCheckPoint 500;
SetDO LimitSpeedDO,high;
FOR i FROM 1 TO 8 DO
FOR j FROM 1 TO 52 DO
HighRingJoint i,j; ! Runs through a function to assign calibrationPos with the next point on the list
MoveAbsJ CalibrationPos,SpeedSelect\T:=TimeSelect,ZoneSelect,currentTool;
ENDIF
ENDFOR
ENDFOR
Each of the positions the robot is moving to is a joint target.
SpeedSelect is set to v1000 and zoneSelect is z50.
When I noticed that this didn't work I then tried running the program by removing the time component to the move but I am still not seeing the correct response
When I run the simulation (without the time component) without the speed limit the robot will run at 1000mm/s, but as soon as I use the speed limit it drops to about 100mm/s.
Is anyone able to help with this?
I am using the speed in current Wobj signal in the signal analyzer to see the results.
Not sure what is happening there try using Velset instead.
So I tried Velset but it doesn't work when you have the time component in the instruction.
It did work though when I got rid of the time component and just had the speed set.
I need the time aspect to work though.0
