RAB 5.07 translation to 5.08
DiMo
Hi All,
I have big problems translating an application compiled with RAB 5.07 (VS 2005) with RAB 5.08. If i translate the application VS comes up with tons of errors like:
Typ "ABB.Robotics.Tps.Windows.Forms.GTPUMessageBox" not defined
Typ "GTPUMasterDialog" not defined
Typ "ABB.Robotics.Tps.Windows.Forms.ComboBox" not defined
Typ "ABB.Robotics.Tps.Windows.Forms.CommandBar" not defined
What's wrong? This is urgent please help me out.
Thanks for your help
DiMo
DiMo
I don't have RAB but for me it sounds like you need to point out your assemblies location.
Right click on the class node and select properties then select "Reference Paths". Browse to and add the path to your RAB assemblies.Per Svensson
Consat Engineering0
