System Crash
neil
I have set up a system with 3 external axes (XYZ axes) using RobotStudio 5.08. The mechanism used for the external axes is created from imported CAD drawings. Sometimes the station containing the mechanism does not open, and the following *.dmp file is generated
2007-07-02_162251_RobotStudioReport_2007-0702_153814.zip
Does anybody know why RS keeps crashing?
Thanks in advance
Thanks in advance
The most recent dump files seem to be Direct3D related, specifically the coordinate system in the lower left corner. I recommend you to
1) Make sure you have the latest drivers for your graphics card
2) Disable the coordinate system (Tools -> Options -> Graphics Appearance)
3) Switch to OpenGL renderer
regards,
Johannes
Johannes Weiman
Software Engineer
ABB Robotics0
- 858 RAPID Programming
