Sockets with omnicore?
Hello!
I would like to use the LAN port to communicate with a camera. I have defined the port address and also enabled RapidSockets for the IO network port, firewall
When I try yo connect the client (camera) I always recieve the error 41575. (The specified address is invalid. The only valid addresses are any public WAN addresses or the service port address, 192,168,125,1)
Back in the days we had this option PC interface, but for Omnicore/RW7??
Hi !I'm not sure if it affects only RobotStudio communication from other than management port but equivalent to "PC Interface" on Omnicore should be "3119-1 RobotStudio Connect" option.Fritz.
