Calculate reltool offsets between two points
what I'm looking for is some sort of an inverse of the Reltool function.
I want to calculate the pose variables needed for a reltool movement to go from a point pA to a point pB.
For example, if I want to move from a point pA, 5 mm along the X coordinate of the tool i can find the next point with:
pB:=RelTool(pA,5,0,0 \Rx:=0,\Ry:=0,\Rz:=0);
But if I have pA and pB, how can I find the offsets? For example:
PERS pose Offset;
Offset:=myFunc(pA, pB);   ! Offset=[[5,0,0],[1,0,0,0]]
So I can do:
Xrot:=EulerZYX(\X, Offset.rot);
Yrot:=EulerZYX(\Y, Offset.rot);
Zrot:=EulerZYX(\Z, Offset.rot);
MoveL pA,vmax,fine,tool0;
MoveL RelTool(pA, Offset.trans.x, Offset.trans.y, Offset.trans.z \Rx:=Xrot \Ry:=Yrot \Rz:=Zrot),vmax,fine,tool0;
Kind regards,
Francesco
  • mandolas
    mandolas
    edited October 2024
    HI ...
    If I understand correctly, you want to go from one point to another, if it is the same tool (pos:=pA.trans-pB.trans) with a digest tool, for that, the CalcJoint() function can help you with that
    MoveL CalcRobT(CalcJointT(pB,tool1),tool0),vmax,fine,tool0;
    Good job.
  • Hi,
    If I understand the question, try the following:
      FUNC pose myFunc (robtarget pA, robtarget pB)
          var pose poseA;
          var pose poseB;
          VAR pose result;
          poseA.trans:=pA.trans;
          poseA.rot:=pA.rot;
          poseB.trans:=pB.trans;
          poseB.rot:=pB.rot;
          result:=PoseMult(PoseInv(poseA),poseB);
          RETURN result;
      endfunc
    Ted
