RAPID Message Queue with PC SDK
I am getting error "A RMQ message was discarded in task T_ROB1. RMQ_T_ROB1 received a RMQ message that couldn't be handled."
What Exactly I am doing wrong here ?
public class Test
public class Test
IpcQueue myQueue;
private IpcQueue tRob1Queue;
private IpcMessage sendMessage;
private IpcMessage recMessage;
public Test()
// _Camera.AprilTagCordinatesChanged += DMDecoder_CordinatesChanged;
/// <summary>
/// The main entry point for the application.
/// </summary>
[MTAThread]
public void start()
NetworkScanner scanner = new NetworkScanner();
scanner.Scan();
System.Threading.Thread.Sleep(2000);
scanner.Scan();
var ControllerInfos = scanner.Controllers;
var ctrl = Controller.Connect(ControllerInfos[0], ConnectionType.Standalone);
ctrl.Logon(UserInfo.DefaultUser);
Console.WriteLine("Controller-System: {0} time is: {1} System ID is: {2}", ctrl.SystemName, ctrl.DateTime, ctrl.SystemId);
Console.WriteLine("Press any key to terminate");
// Get the T_ROB1 queue to send messages to the RAPID task
tRob1Queue = ctrl.Ipc.GetQueue("RMQ_T_ROB1");
// Create my own PC SDK queue to receive messages
if (!ctrl.Ipc.Exists("PC_SDK_Q"))
myQueue = ctrl.Ipc.CreateQueue("PC_SDK_Q", 5, Ipc.IPC_MAXMSGSIZE);
myQueue = ctrl.Ipc.GetQueue("PC_SDK_Q");
ctrl.EventLog.MessageWritten += EventLogMessageWritten;
recMessage = new IpcMessage();
sendMessage = new IpcMessage();
SendMsgToRapid();
static Controller CreateController()
try
Guid test = new Guid();
Controller controller = new Controller(ControllerFactory.FormatControllerId(new Guid()));
return controller;
catch (Exception ex)
Console.WriteLine("The specified GUID cannot be found. The robot GUID can be found in the internal directory in the 'system.guid' file. The current sysID is: " );
Console.ReadKey();
Environment.Exit(1);
return null;
private void SendMsgToRapid()
Thread.Sleep(5000);
try
while (true)
SendMessage(true);
CheckReturnMsg();
Thread.Sleep(10000); // Send every 10 seconds
Console.WriteLine($"{ex.Message}");
throw ex; // Rethrow to notify caller
public void SendMessage(bool boolMsg)
byte[] data = null;
// Create message data
if (boolMsg)
data = new UTF8Encoding().GetBytes("bool;TRUE");
else
data = new UTF8Encoding().GetBytes("bool;FALSE");
// Place data and sender information in message
sendMessage.SetData(data);
sendMessage.Sender = myQueue.QueueId;
// Send message to the RAPID queue
tRob1Queue.Send(sendMessage);
private void CheckReturnMsg()
Thread.Sleep(5000);
IpcReturnType ret = IpcReturnType.Timeout;
string answer = string.Empty;
int timeout = 5000; // 5 seconds timeout
// Check for a message in the PC SDK queue
ret = myQueue.Receive(timeout, recMessage);
if (ret == IpcReturnType.OK)
// Convert message data to string
answer = new UTF8Encoding().GetString(recMessage.Data);
Console.WriteLine(answer); // Should show: "Acknowledged"
else
public static void EventLogMessageWritten(object sender, MessageWrittenEventArgs e)
if (sender != null && e != null)
Console.WriteLine(e.Message.Title);
// Additional code for event logging could be placed here
else
Console.WriteLine("Null Event Log Message");
###Rapid code
MODULE RAB_COMMUNICATION
VAR bool flag := FALSE;
VAR intnum connectnum;
PROC main()
CONNECT connectnum WITH RABMsgs;
IRMQMessage flag, connectnum;
WHILE flag = FALSE DO
!do something, eg. normal processing...
WaitTime 3;
ENDWHILE
!PC SDK message received - do something...
TPWrite "Message from PC SDK, will now...";
IDelete connectnum;
EXIT;
TRAP RABMsgs
VAR rmqmessage msg;
VAR rmqheader header;
VAR rmqslot rabclient;
VAR num userdef;
VAR string ack := "Acknowledged";
RMQGetMessage msg;
RMQGetMsgHeader msg \Header:=header
\SenderId:=rabclient\UserDef:=userdef;
!check data type and assign value to flag variable
IF header.datatype = "bool" THEN
RMQGetMsgData msg, flag;
!return receipt to sender
RMQSendMessage rabclient, ack;
ELSE
TPWrite "Unknown data received in RABMsgs...";
ENDIF
ENDTRAP
ENDMODULE0
