Understanding DH Parameters in Robot XML
Hi all,
I am currently trying to wrpa my head around the DH parameters that are present in the PIM.xml for the IRB6400 robot.
When attempting todo forward kinematic calculations with the robot, I am not getting the same values as reported by the flexpendant.
XML Below:
<JointInfos>
                <Element>
                    <IsRevoluteJoint Value="true" />
                    <DHParameters>
                        <Element>
                            <NextJoint Value="1" />
                            <Link Value="1" />
                            <Twist Value="0" />
                            <Length Value="0" />
                            <Rotation Value="0" />
                            <Offset Value="0" />
                        </Element>
                        <Element>
                            <NextJoint Value="9" />
                            <Link Value="-1" />
                            <Twist Value="0" />
                            <Offset Value="0.27" />
                        </Element>
                    </DHParameters>
                </Element>
                <Element>
                    <DHParameters>
                        <Element>
                            <NextJoint Value="2" />
                            <Link Value="2" />
                            <Twist Value="-1.5707963267949" />
                            <Length Value="0.24" />
                            <Rotation Value="-1.5707963267949" />
                        </Element>
                        <Element>
                            <NextJoint Value="8" />
                            <Link Value="-1" />
                        </Element>
                    </DHParameters>
                </Element>
                <Element>
                    <DHParameters>
                        <Element>
                            <NextJoint Value="3" />
                            <Link Value="3" />
                            <Twist Value="0" />
                            <Length Value="1.05" />
                        </Element>
                        <Element>
                            <NextJoint Value="6" />
                            <Link Value="-1" />
                            <Twist Value="0" />
                        </Element>
                    </DHParameters>
                </Element>
                <Element>
                    <DHParameters>
                        <Element>
                            <NextJoint Value="4" />
                            <Link Value="4" />
                            <Length Value="0.225" />
                            <Offset Value="1.52" />
                        </Element>
                    </DHParameters>
                </Element>
                <Element>
                    <DHParameters>
                        <Element>
                            <NextJoint Value="5" />
                            <Link Value="5" />
                            <Twist Value="1.5707963267949" />
                            <Rotation Value="-3.14159265358979" />
                        </Element>
                    </DHParameters>
                </Element>
                <Element>
                    <DHParameters>
                        <Element>
                            <NextJoint Value="-1" />
                            <Link Value="6" />
                        </Element>
                    </DHParameters>
                </Element>
                <Element>
                    <DHParameters>
                        <Element>
                            <NextJoint Value="7" />
                            <Link Value="7" />
                            <Twist Value="0" />
                            <Length Value="0.4" />
                        </Element>
                    </DHParameters>
                </Element>
                <Element>
                    <DHParameters>
                        <Element>
                            <Link Value="8" />
                            <Twist Value="0" />
                        </Element>
                    </DHParameters>
                </Element>
                <Element>
                    <DHParameters>
                        <Element>
                            <Link Value="9" />
                            <Twist Value="0" />
                        </Element>
                    </DHParameters>
                </Element>
                <Element>
                    <DHParameters>
                        <Element>
                            <Link Value="10" />
                            <Length Value="0.276" />
                        </Element>
                    </DHParameters>
                </Element>
With my understanding, where Link Value = '1', this represents the transofrmation of the base frame to link 1, and then Link Value = '2' represents the transformation parameters from joint 1 to joint 2. Although this raises questions about why there are more than 6 joint values
Please can someone inform me if I am correct?
Best Regards,
Joe
