GSD File errors TIA Portal
Hello everybody,
Currently I'm developing an aplication consisting in an ABB IRB1200 robot and a Siemens S7-1211C PLC, between which I try to establish a Profinet communcation.
The GSD file is: GSDML-V2.21-ABB Robotics-INTERNAL-Robot Device-20191114.xml
The problem is that when I try to import the corresponding GSD file in TIA Portal I receive the following error messages:
gsdml-v2.32-abb robotics-internal-robot device-20191114.xml
:General GSD Error: Check-Number: 0x00010123_1,Message: For F submodules 'Consistency'="All items consistency" must be given for 'Output'.,Line: 1459,XPath: //ModuleItem[@ID='18']/VirtualSubmoduleList/VirtualSubmoduleItem[@ID='18'],
:General GSD Error: Check-Number: 0x00010128_2,Message: 'F_ParameterRecordDataItem/@F_ParamDescCRC': The CRC over all F parameters is 4774, but should be 45471.,Line: 1434,XPath: //ModuleItem[@ID='17']/VirtualSubmoduleList/VirtualSubmoduleItem[@ID='17']/RecordDataList/F_ParameterRecordDataItem/@F_ParamDescCRC[.='4774'],
:General GSD Error: Check-Number: 0x00010128_2,Message: 'F_ParameterRecordDataItem/@F_ParamDescCRC': The CRC over all F parameters is 4774, but should be 45471.,Line: 1478,XPath: //ModuleItem[@ID='18']/VirtualSubmoduleList/VirtualSubmoduleItem[@ID='18']/RecordDataList/F_ParameterRecordDataItem/@F_ParamDescCRC[.='4774'],
:General GSD Error: Check-Number: 0x00010128_2,Message: 'F_ParameterRecordDataItem/@F_ParamDescCRC': The CRC over all F parameters is 4774, but should be 45471.,Line: 1530,XPath: //ModuleItem[@ID='19']/VirtualSubmoduleList/VirtualSubmoduleItem[@ID='19']/RecordDataList/F_ParameterRecordDataItem/@F_ParamDescCRC[.='4774'],
:General GSD Error: Check-Number: 0x00010129_1,Message: '(Virtual)SubmoduleItem/IOData/@F_IO_StructureDescCRC': The CRC over all IOData is 7612, but should be 33954.,Line: 1417,XPath: //ModuleItem[@ID='17']/VirtualSubmoduleList/VirtualSubmoduleItem[@ID='17']/IOData/@F_IO_StructureDescCRC[.='7612'],
:General GSD Error: Check-Number: 0x00010129_1,Message: '(Virtual)SubmoduleItem/IOData/@F_IO_StructureDescCRC': The CRC over all IOData is 33954, but should be 7612.,Line: 1461,XPath: //ModuleItem[@ID='18']/VirtualSubmoduleList/VirtualSubmoduleItem[@ID='18']/IOData/@F_IO_StructureDescCRC[.='33954'],
I hope that you can help me solve the problem to be able to insert the GSD File and configure the Profinet communcation.
Claudiu Muresan
Claudiu Muresan
Try not using the GSD file with "INTERNAL" in the filename.
nicolahinssen said:Try not using the GSD file with "INTERNAL" in the filename.0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 341 IRC5
- 69 OmniCore
- 840 RAPID Programming
- 19 AppStudio
- 107 Collaborative Robots
