Is it possible to custome service routines?
laov
Not sure if this is the right section but I could not find a FlexPendant topic so here goes:
Is it possible to create a sub category of my own in flexpendant debug, call routine section? Or add my own routine into service routines? I would like to define some maintenance routines - moving robot to a certain maintenance possition and returning from it reliably for the average operator.
Best Answer
Hello,You can add it in MMC.cfg file in MMC_SERV_ROUT_STRUCT: section
DenisFR said:Hello,You can add it in MMC.cfg file in MMC_SERV_ROUT_STRUCT: section
All Routines
My Routines
Service Routines
Is this possible?0
- 5.5K RobotStudio
- 396 UpFeed
- 18 Tutorials
- 13 RobotApps
- 297 PowerPacs
- 405 RobotStudio S4
- 2.8K Robot Controller
- 316 IRC5
- 61 OmniCore
- 798 RAPID Programming
- AppStudio
- 3 RobotStudio AR Viewer
- 18 Wizard Easy Programming
- 105 Collaborative Robots
