webware website posting http404 error [WebWare Server]
I am receiving a http404 error file not found when i go to the
http://br-c131a-01/webware
The image that i am running is windows xp with sp2 and it is a custom image that was installed from the college that i work at.
Any help would be great
Thanks
  • You need to give a lot more info if you want people to help you.
    Like which version of the product you have. How you tried to publish the website etc.
    To me it sounds more like you have a problem with Internet Information Services then that the problem is in WebWare. So whatever settings you have tried in IIS would be necessary as well.
  • Maybe you are trying to reach a network host. The address looks like it should only be available if you are actually plugged in at your college network.
