Scalable I/O in Simulated Robot Studio and Teach Pendant
im new to robot studio.
I have installed RobotStudio 2024 on Windows 11 and want to set up a configuration in simulation. I created a setup with a GoFa15000 and a simulated controller. For the controller i want a Scalable I/O DSQ1030 to be installed. I managed to install the DSQ1030 and i see the Signals under I/O Engineering. The simulated controller is started.
Question: How can i use the I/Os from the DSA1030 in the simulated FlexPendant? These I/Os don't show up automatically, also not after restart. If there is a tutorial: What do i have to look for?
Many thanks!
Many thanks!
If the DSQC1030 has been configured correctly, the I/OS should be visible in the simulated FlexPendant: Main menu->I/O -> EthernetIP
