SYSPAR folder does not appear in the project.
Hi...
May you can help please with this question:
I am using a Virtual Controller Omicore E10, Roboware 7.16.2.
My project does no have the SYSPAR folder, so, I have created the EIO.cfg and I want to
add it into the project, but I don't see how to put this cfg file in the project because I don't have the aforementioned SYSPAR folder...am I seeing the issue correctly?
I know that normally into the SYSPAR folder can be found the EOI.cfg; MMC.cfg; MOC.cfg...and more.
How can I relate my EIO created for this project?
Thank you for your support on this!
BBB
  • When working with a project rather than a backup, you will not have a SYSPAR folder. Instead in the controller tab of robot studio, you can either right click on the configuration section of controller or find the Load and save Parameters button in the ribbon bar to load the EIO file your created.
    Otherwise, take a backup of the virtual robot and make your modifications to the backup as that will have the SYSPAR folder. Then reupload the backup.
    Good luck, feel free to reach out with questions.
  • Hi Revans,
    Thank you for you support on this, appreciated!
    I found also that we can load the EOI into the HOME folder, I presume with same result.
    But I will check as you said.
    Thank you!
    BBB
