Socket communication error
Hello everybody,
I'm currently trying to estabish a socket communcation between an ABB IRB1200 Robot and a 3D Camera from Solomon. The controller has the PC-Interface package installed, the robot IP is 192.168.0.6 and the PC has the IP 192.168.0.2 and the declared port 10000. I can succesfully create the Socket but when it reaches the SocketConnect command it idles there until the timeout error occures. I was wondering if you have any ideas for this problem. Thank you very much!
!Creating socket and verifying
SocketCreate SocketSolomon;
IF (SocketGetStatus(SocketSolomon)=SOCKET_CLOSED) THEN
TPWrite "Socket failed to create!";
SocketFails:=SocketFails+1;
GOTO VisionInit;
ELSE
TPWrite "Socket created successfully!";
ENDIF
!Connecting socket and verifying
SocketConnect SocketSolomon,"192.168.0.2",10000;
IF (SocketGetStatus(SocketSolomon)<>SOCKET_CONNECTED) THEN
TPWrite "Failed to Connect!";
SocketClose SocketSolomon;
GOTO VisionInit;
ELSE
TPWrite "Socket connected successfully!";
ENDIF
Hi ...There is a time for creation, connection and data exchange, in addition there is a number of sockets and connections that are allowed, so try not to create/connect too many sockets.I believe you are not giving enough time for the commands to complete.Try the solution to see what appears as a response.
PROC ConnectServerSocket(string addressP,num portP) ! ## ATTRIBUTES ############################################# ############################## VAR socketdev mySocketL; ! ## ATTRIBUTES ############################################# ############################## ! Creates a connection via socket if there is no connection created with the PLC for data exchange ... IF SocketGetStatus(mySocketL)<>SOCKET_CREATED THEN SocketCreate mySocketL; ENDIF IF SocketGetStatus(mySocketL)=SOCKET_CREATED THEN SocketConnect mySocketL,addressP,portP\Time:=1; IF SocketGetStatus(mySocketL)=SOCKET_CONNECTED THEN ! CODE .... ENDIF ENDIF ! At the end of the routine, close the connection with the PLC to avoid creating an unnecessary socket when executing the routine again ... SocketClose mySocketL; RETURN ; ERROR ! #################### ##################### ! ! #################### Handling error ################### ! ! #################### #################### ! TEST ERRNO CASE ERR_SOCK_TIMEOUT: ErrWrite "ERR_SOCK_TIMEOUT",""; CASE ERR_SOCK_CLOSED: ErrWrite "ERR_SOCK_CLOSED",""; DEFAULT: TPWrite "??? ERRNO ???"; ENDTEST ! Testando o status do socket para definir ações a serem tomadas ... TEST SocketGetStatus(mySocketL) CASE SOCKET_CREATED: TPWrite "SocketCreate"; CASE SOCKET_CLOSED: TPWrite "SocketClose"; CASE SOCKET_BOUND: TPWrite "SocketBind"; CASE SOCKET_LISTENING: TPWrite "Instruction SocketListen or SocketAccept has been executed"; CASE SOCKET_CONNECTED: TPWrite "SocketConnect, SocketReceive or SocketSend"; DEFAULT: TPWrite "??? SocketGetStatus ???"; ENDTEST RETURN ; ENDPROCGood Job.0
