Robotstudio smartcomponent LinearMover simulation
Chris96
Im trying to move parts on conveyor. I have a problem with simulating linearmover. When i execute (1) linearmover, object does not move. Dont know what am I doing wrong. Simulation stops immediately when i press play. Tried to follow many youtube tutorials and none seem to have this problem. Is there setting I need to change ?
Version 24.2.10821.1
Tried in older (2021) version and linearmover works just fine.
Thanks for any advice.
Hi ...In certain situations it is necessary to include a controller in the station so that the simulation can be executed.Try including a controller and in the 'main' insert an infinite loop. This should solve your problem.Good Work0
Or you can add a Timer SmartComponent in 'Signals and Properties' and set a repeat interval larger than 0 to let the simulation running in an infinite way.0
