UIShow in RobotWare 7?
I need to open the program editor on the FlexPendant from my RAPID code. In RW5/6 I did so using the "UIShow"-command. In RW7, this command doesn't seem to be doing anything, it is also no longer a part of the RAPID Reference Manual.
I can load a module which contains an "UIShow" statement without errors to a RobotWare 7 controller, but it just seems to be doing nothing.
Does anyone know if there is a command with same functionality in RobotWare 7 and if so, what is it's name?
Thanks!
Hi ...Some functions were removed and/or had their names changed or now have more or less parameters.Others just changed the name of the parameter. I don't know why these changes were made, since they seem to do the same thing, so there was no need to change them.I believe it is to 'simulate' that there are new features.Take a look at the 'UIDisplay' function, which has the same parameters as 'UIShow', but the result seems to be more generic.Good work.0
