Handling motion error 50050
I was wondering if it is possible to handle someway the error 50050 " Position outside reach" via Error handler or in some other way.
I would like that if this error happens, robot will continue the execution from the next instruction.
Thank you!
Thank you!
Hallo, you may try to calculate a jointtarget from your intended robtarget. The function CalcJointT can generate an recoverable error, when the robotarget is out of reach. See description for the function.1
Thank you, I'll try that!0
- 37 AppStudio
