downgrade after upgrade robotware
In Robotstudio/Installation/Modify Installation -> Update:  Robotware 7.15.4 was updated to Robotware 7.16.2.
How can I go back to Robotware 7.15.4? There is no option to downgrade after the update?
Daniel
  • lemster68
    lemster68 ✭✭✭
    Did you install the system into the contoller?
    Lee Justice
  • daniel72
    daniel72
    edited March 5
    I did: In Robotstudio/Installation/Modify Installation -> Update
    the controller then updated itself to RW7.16
    The problem is that the IO configurator is now crying that it can't handle RW7.16 and there doesn't seem to be a version of the IO configurator that fits RS7.16
    I expected there to be a way back  but it doesn't seem to be possible!?
    Daniel
  • lemster68
    lemster68 ✭✭✭
    Cold start the controller.  Delete that system in Robotstudio and make another with 7.15.
    Lee Justice
  • I used RS2024.3 yesterday, but this version cannot handle Robotware 7.16.
    With RS2025.1 it is possible: to go back to an older version under: Robotstudio/Installation/Modify Installation -> Update (here now is selection possible)
    The option to create a new system or a system from a backup as in RW5 and RW6 does not seem to be possible in RW7 or RS2025.1 until now.
    Daniel
