On the omnicore controller it ask to simulate waittime. How do I stop this from asking everytime?
I am using a CRB 15000 with a omnicore controller. I'm running a code to pulsedo to a motor controller with a waittime. It looks like:
  PROC main()
        FOR i FROM 1 TO 1000 DO
            PulseDO DO10;
            waittime 500;
        ENDFOR
ENDMODULE
Every time it hits waittime it ask if I want to simulate the waittime on the controller and stop the program until I click ok. How do I get it to stop doing this?
Best Answer
  • Tompanhuhu
    Tompanhuhu ✭✭✭
    edited March 2025 Answer ✓
    Go to topic Controller, General Rapid and set SimulateMenu to No
    But sometimes you might want to keep the SimulateMenu for robot task, in that case you can do multiple smaller waittimes and the menu won't show.
            FOR i FROM 1 TO 5000 DO
                waittime 0.1;
            ENDFOR
    Or you could use timer interrupt instead of locking the task in a waittime for 500 seconds.
    MODULE Module1
        VAR intnum inPulseSignal;
        PROC main()
            !Setup timer-trap
            CONNECT inPulseSignal WITH trapSignalPulse;
            ITimer 500,inPulseSignal;
            !Timer will now run once every 500s without locking the task
            WHILE TRUE DO
                !Do different stuff
                waittime 0.01;
            ENDWHILE
        TRAP trapSignalPulse
            PulseDO DO10;
        ENDTRAP
    ENDMODULE
  • lemster68
    lemster68 ✭✭✭
    For IRC5 there is a simulate parameter under the controller topic which can be set to 0 to disable the simulate dialog box.  Poke around and see if it is still available on the omnicore.
    Lee Justice
