Problem writing RobTarget
When I try to write a RobTarget to the controller, I then get the following error: An argument specified by the client is not valid for this type of operation.
The data that I use, works fine by other rapid types, for example Pos or Orient.
Code:
string[] valName = { Controller.GetTaskName(), moduleName, name };
RobTarget data;
data = (RobTarget)Controller.GetRapid().GetRapidData(valName).Value ;
data.Trans.X = (float)x;
data.Trans.Y = (float)y;
data.Trans.Z = (float)z;
data.Rot.Q1 = (double)q1;
data.Rot.Q2 = (double)q2;
data.Rot.Q3 = (double)q3;
data.Rot.Q4 = (double)q4;
data.Robconf.Cf1 = (int)config1;
data.Robconf.Cf4 = (int)config4;
data.Robconf.Cf6 = (int)config6;
data.Robconf.Cfx = (int)configX;
System.Array arr = (System.Array)axis;
data.Extax.Eax_a = (float)arr.GetValue(0);
data.Extax.Eax_b = (float)arr.GetValue(1);
data.Extax.Eax_c = (float)arr.GetValue(2);
data.Extax.Eax_d = (float)arr.GetValue(3);
data.Extax.Eax_e = (float)arr.GetValue(4);
data.Extax.Eax_f = (float)arr.GetValue(5);
Controller.GetRapid().GetRapidData(valName).Value = data;
The error will occure at the last line of code.
  • Hi,
    is the robtarget defined as a variable or a constant in the RAPID code? As far as I know, you cannot write to a RAPID constant.
    BR
    Ren?
  • Thnks Rene, that was the problem.
