Trying to get a value at an index point in an array
I am trying to access a certain array index value.
Example code:
PERS num array{10}; !!! example array [1,2,3,4,5,6,7,8,9,10]
VAR num maxVal;
PROC maxSearch()
maxVal := array[1] !!! trying to get value at index 1 of array, but getting an error stating " wrong array dimensions" , trying to access value: 1 in the array [1,2,3,4,5,6,7,8,9,10].
Example code:
VAR num maxVal;
PROC maxSearch()
Instead of the brackets you need to use the curly braces. {}Lee Justice0
