Help Loading an Pack an Go File
PeterPan
Hello Team I got an Pack and go File from an Client my older Robot Studio couldnt open it.
So I installed the Latest Robotstudio with an Test license.
I run now into an Problem opening the file.
anyone an Idea?
Its Windows 11 Pro
20.06.2025 14:54:57
RobotStudio .NET exception: system creation failed due to
ABB.Robotics.RIM.InternalSystemException:
Python Layer: (Trigger: UpdateSettings) Internal System Error.
bei ABB.Robotics.RIM.HostDataProvider.UpdateSettings(ICollection`1 products, String ctrlName, String location)
bei ABB.Robotics.RIM.VCController.UpdateSettings(Settings2 settings, Boolean IsCreateSystem)
Base exception: SystemCreationFailedException
bei ABB.Robotics.RIM.RobInstallManager.CreateVirtualController2(ControllerSystem2 cSys, String controllerLocation, String productsInstallationParentPath)
bei RobotStudio.Services.Systems.SystemBuilder.SystemBuilderRW6.<>c__DisplayClass1_0.<CreateVirtualController>b__0()
bei System.Threading.Tasks.Task.Execute()
--- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde ---
bei System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
bei RobotStudio.Services.Systems.SystemBuilder.SystemBuilderRpkBase.<CreateSystemFromBackupAsync>d__13.MoveNext()
bei ABBInternal.StationManagement.PackAndGoService.<CreateSystem>d__17.MoveNext()
bei ABBInternal.StationManagement.PackAndGoService.<UnpackAndWork>d__14.MoveNext()
anyone an Idea?
Its Windows 11 Pro
Hi Peter,
If I recall correctly you need to have a specific IronPython version installed.
The version of IronPython required by RIM is 2.7.4 and it can be downloaded from 'https://github.com/IronLanguages/main/releases/download/ipy-2.7.4/IronPython-2.7.4.msi'.
Ok I installed the IronPython and restarted to PC
Did try to open the pack and go but getting the same result.
Not sure if the Actual RobotStudio have bigger Problems cause I tried to open an Older PackandGo file that I could open with Version 2023 and try open it with latest I get:RobotStudio .NET exception: Option "abb.robotics.robotware.robots.irb2600.12-1_65.typec" is not part of the added product manifest files features, check the feature name or dependency products============================================
If check in the ABB LIbrary the Robot is there.
Or Maybe its an Windows 11 Problem cause As I tried creating the Conroller manualy from Backup I get:RobotStudio .NET exception: C0040403 : No response from controller.Netscan timeout============================================Base exception: RobApiExceptionC0040403 : No response from controller.Netscan timeout0 -
Yeah, it sounds like there might be something on your PC that is preventing the controller from either be created, or started, or both.
Check if you have some anti-virus blocking the RobotStudio processes such as InstallationManager.exe in the RS installation folder, and RobVC.exe in C:\Program Files (x86)\Common Files\ABB Industrial IT\Robotics IT\RobVCCommon
