How to remove old files from directory (Selected by date)
VAR string stFileName;
VAR iodev logfile;
Write logfile,stTimeLogs;
Close logfile;
http://www.luxrobotic.com
Is there a possibility of writing your files to an external device?
It has been observed writing to a Windows PC and running a batch file, or PowerShell script, against the folder with the files has worked.Post edited by SomeTekk on0 -
Hi SomeTekk,I have to try.I'll keep you inform, but I can't do it quickly.ThanksRegardsCornet RaymondManager+352 621 354 570raymond.cornet@luxrobotic.com
http://www.luxrobotic.comHP ZBook Fury 16 G110 -
I am a bit fuzzy on exactly what options are necessary.
The RAPID REFERENCE Manual was a great tool used to get the results I needed exported to an external destinaton.
Here's an AI generated PowerShell script deleting old files and folders:# Set parameters
$targetDir = "C:\Path\To\Your\Directory"
$daysOld = 30
# Calculate cutoff date
$cutoffDate = (Get-Date).AddDays(-$daysOld)
# Delete files older than the cutoff date
Get-ChildItem -Path $targetDir -Recurse -File | Where-Object {
$_.LastWriteTime -lt $cutoffDate
} | ForEach-Object {
try {
Remove-Item $_.FullName -Force
Write-Host "Deleted file: $($_.FullName)"
} catch {
Write-Host "Failed to delete file: $($_.FullName) - $_"
# Delete empty directories
Get-ChildItem -Path $targetDir -Recurse -Directory | Sort-Object -Property FullName -Descending | ForEach-Object {
if (-not (Get-ChildItem $_.FullName -Recurse)) {
try {
Write-Host "Deleted empty directory: $($_.FullName)"
} catch {
Write-Host "Failed to delete directory: $($_.FullName) - $_"
Best of luck!0
