How to show array content in dropdown list?
If you want it to grab data you retrieve somewhere, you can create the dropdown menu like this. You can use/adjust this code to make it work for you.const dataNames = [];if (regex) {let match;while ((match = regex.exec(content)) !== null) {dataNames.push(match[1]);}console.log(`🔧 Gevonden ${dataLabel} namen:`, dataNames);} else {console.warn("⚠️ Geen actieve knop gevonden. Kies een knop.");}const optionString = dataNames.length? [...new Set(dataNames)].map(name => `${name}|${name}`).join(";"): `No ${dataLabel || "Data"} found|`;Instance.Select_WeldParametersData.optionItems = optionString;
