Communication TIA14 to Robot
PeterPan
Hello Team
I tried to import an project from an Siemens PLC into TIA Portal V14 and run into an not possible cause GSD files missing.
So I imported the files from the Home folder into it (also tried from the product folder as mentioned in another post) but am still not able to Import the project.
TIA Portal Shows this Error
The PLC contains additional data of the following products: Working with the PLC loaded from the device may only be possible with restrictions since the PLC was previously loaded with the following installed products from a different project environment: dsqc352b.gsd Rev. 2.0
I googled for help but not getting the file or further help.
Anyone an Idea how to solve this?
Cheers
Peter
Cheers
Peter
- 38 AppStudio
