Why does ABB not support Custom Proc syspars? (Found a fix)
Does anyone know the reason why ABB removed the possibility to create customized system parameters in a RobotWare add-in for Omnicore?
The possibility to use the invoke command in the install script is removed in Omnicore and it seems to be needed to make use of customized system parameters.
Edit: Invoke is not needed, It seems to be working when directly calling cfg_create_type_from_rules_def. (works on VC, not tested on RC)
//Markus Näslund
Post edited by Markus Näslund on
