IRT710 lubrification
We have a IRT710 axis with automatic lubrication (MEMOLUB EPS pump controlled by the robot via a digital output).
ABB recommended activating the pump every 6 days in the product manual.
I would like to activate the pump depending on the distance traveled by the axis. Is there a way in RAPID to read the distance traveled by the IRT710, e.g., from the SIS data, like the gearbox hours of the 710?
Thank You
Daniel
Best Answer
  • lemster68
    lemster68 ✭✭✭
    Answer ✓
    Yes.  There is a function, GetAxisDistance, that will return a Dnum of the distance traveled in meters for a linear track or degrees for a rotational axis.
    Lee Justice
