EtherNET/IP configuration error
czagawara
czagawara
edited November 2025 in OmniCore
 Hi all,
I'm on RobotStudio 2025.3 Robot 1010 E10 controller RobotWare 7.15.2 Omnicore
Im configuring  3024-2 EtherNet/IP Adapter in IO engineering
When using RobotWare 7.15.2, every time I press 'Write the configuration' I'm getting an error from the picture.
 I built the virtual station and I have the same results. When I change to e.g., 7.19, the problem is gone and all is working OK."
Did anyone expereince anything like this before ?
https://1drv.ms/i/c/61525fb784a63d0a/ES1Xlb_C6BpOrLoPVfmz55sBOySv9ZmKGYs5mrQVBqnOYQ?e=UDjRWq
Regards
Bart
