checkbox in appstudio
i want to use a checkbox in appstudio but i can not found how to bind it with a bool in rapid code. greetings
I created a function in a class that checks whether a component should be active or not. You can change this to require a signal and then do the following:
updateUiIcon() {const active = this.isActive();this.component.icon = active? "abb-icon abb-icon-abb_check-mark_16": null;}isActive() {return this.component.toggle === 1;}1
- 855 RAPID Programming
- 38 AppStudio
