Backup Directory for Omnicore VC
Hello,If you put your Backup into Home, your next backup will contain it, and so on...☑️2024 - RobotStudio® User Group0
Makes sense. I can't seem to take a backup to any other location besides the BACKUP directory though. I can't specify a path to my own directory at the same level as BACKUP. On IRC5s, the path "SYSTEM:custom-directory" was valid for backups taken via system input, but that doesn't seem to work on omnicore. At least not for virtual controllers.0
I'm forced to put my rapid modules in the HOME directory because I can't seem to access any directories at the SYSTEM level besides HOME, BACKUP, and maybe TEMP.0
