How can we display a 0–100% water-tank level on the OmniCore HMI when no built-in component exist?
Best Answer
Hi !With Omnicore app SDK you can create pages with HTML and Javascript. No restrictions to use any HTML element. Limitations to use "built-in" components exist only if you use tools like Appmaker etc.Fritz.0
Hi, if you want to create some new element and you want to have some visual thing in appStudio you can use for example layout element and transform it into something different using js. I am for example clearing component container.innerHtml = ''; And after this you can transform it in any other component that you want. I am doing this transformation in layout OnMount event and it works fine.0
RadekL said:Hi, if you want to create some new element and you want to have some visual thing in appStudio you can use for example layout element and transform it into something different using js. I am for example clearing component container.innerHtml = ''; And after this you can transform it in any other component that you want. I am doing this transformation in layout OnMount eventFritz said:
Can you tell please if there is no APP studio how can I deploy in the pentantHi !With Omnicore app SDK you can create pages with HTML and Javascript. No restrictions to use any HTML element. Limitations to use "built-in" components exist only if you use tools like Appmaker etc.Fritz.0 -
If you want to deploy your custom app to the flex you just need to upload it via file transfer to the robot memory into Home\WebApps\yourAppFolder
If there is no WebApps just create it.0 -
my purpose is to make a Water level in the HMI , so how can I do it there is no custom UI, when I try to create by own it is showing some error?
