Missing features in Omnicore App SDK
Hi !
I am basically re-posting my old question (from 2021) here to Omnicore App SDK developers team as proposal/request. I am waiting already long time for some functionalities from IRC5 Flexpendant SDK to be ported into Omnicore App SDK:
  • ABB.Robotics.Controllers.MotionDomain.MechanicalUnit
       * Tool - Gets or sets the active tool;
       * WorkObjectName - Gets or sets the active work object;
       * GetPosition - Gets the joint target position of the mechanical unit;
       * Getposition(CoordinateSystemType) - Gets the robtarget position of the mechanical unit.
  • ABB.Robotics.Controllers.RapidDomain.Task
       * ResetProgramPointer - Resets the program pointer of this task to its main routine;
       * CallRoutine(String, RegainMode) - Starts executing the specified routine.
  • ABB.Robotics.Tps.Taf.ITpsViewLaunchServices.LaunchView(FpStandardView, Object, Boolean, Object) - Launches a View in the FlexPendant (Jogging).
  • ABB.Robotics.Tps.Windows.Forms.
       * FpToolCalibration - Initializes a new instance of the FpToolCalibration class;
       * FpWorkObjectCalibration -Initializes a new instance of the FpWorkObjectCalibration class;
       * FpRapidData(RapidData) - Initializes a new instance of the FpRapidData class.
Basically, I'm looking for possibiulity to:
  • Get and set active tool and workobject;
  • Get current joint and robtarget position;
  • Call and execute rapid routine by name;
  • Show/open/switch-to standard Flexpendant pages (like Jogging);
  • Show/open standard calibration and data editing dialogs with prefilled variable name.
If some of those possibilities already exist, please point them out to me.
Thank you!
Fritz.
  • Hi @Fritz
    Please reach out to your local ABB with these questions/suggestions.
    Thanks!
    Maxim Riabichev
    PC Software Support Engineer
