how to configure the moc.cfg parameteres of a custom track under RW7
I get a documentation from ABB france in order to create and parametrize a custom track (so not from ABB library). This documentation was once dedicated to the robotware system up to 6.xx.
From my part i work on robotstudio 2025 and with a RW7 system.
So the first step dedicated to the creation of the mecanism is ok, no problem.
But a the beginning of the "second part" of the document, i have to load a MOC.cfg file used to parametrize the additional drive of the track.
Unfortunately, the folder structure with RW7 does not match those of RW6 sytems and i can not get the link below to load in my virtual system.
Here's an example of a link that i can get in a RW6 folder where i can find the MOC.cfg files i need to load.
<C:\Users\xx.yy\AppData\Local\ABB\RobotWare\RobotWare_6.16.2027\utility\AdditionalAxis\Track\DM1>
But I don't know how find the "track" folder for a RW7 system.
Does anyone can help me?
Hello,You can find some Drive config file here:%LOCALAPPDATA%\ABB\RobotWare\RobotControl_7.20.0\drives\drv1_lib\drvcfgLike EXT_DRIVE_MODULE1_MDU7_24.cfgNot sure if these are what you needs.☑️2024 - RobotStudio® User Group0
Hi Denis, Thks!I have also found that:C:\Users\xx.yy\AppData\Local\ABB\DistributionPackages2\ABB.RobotWare-7.20.0\RobotPackages\RobotControl_7.20.0\utility\AdditionalAxis\Track\DM1It seems to work too.I just have a problem to move the robot attached to the track because i can move the track from the virtual pendant, no pb, it works, but the robot don't move on it !
Post edited by crashtest72 on0
