Restore backup from IRC5 in RobotStudio: but the MOVL not move correctly...
When we are connected with robotStudio(2025) a IRC5 RobotWare 6.13, IRB 1660id with IRBP A250, we create Workobject and attach the Wobj at STN1(external axe), usual for multimove, all is OK!  But when we are not connected to IRC5, we run from the backup or IRC5, the MOVL with simulation make movement not over the Workobject!!!
It's possible we can't run simulation in RobotStudio from the IRC5 Backup?  Because comme package are not available to install in RobotStudio, I can install only from RobotStudio in IRC5 for example smarTac!
If I create from RobotStudio the similar robot/axe external without some package for Welding from Lincoln Electric(because computer don't have physical connection to PowerWave R450 and AutoDrive 4R100), all run correctly in robotStudio.
