Syncronizing Taking Too Long??
bhanscom
When trying to syncronize rather large modules with hundreds, if not thousands of targets, why does it take so long??
What is actually going on that should take so long to incorporate modules with large amounts of target data?
I am using a 3 Ghz processor and 3 Gig of RAM.
By saving the station it doesn't take but 10-30 seconds with all data.
Why such hefty processor resources to syncronize??
Syncronizing to the station is the most demanding. Sync to VC not so bad. And I completely remove all targets and paths from the station before syncronizing since it seems to speed up the process a little bit. I am also only syncronizing the module or data that I want in the station.
Can anyone explain??
