RobotStudio Online
Rod S
Hello...
Could someone tell me which features i lose, if any at all, without having a licenced version of RobotStudio Online.
Thanks.
The main thing is that you cannot make a LAN connection to the robot, i.e. you can only connect via the service port. As a result, you cannot use RSO to connect to more than robot at time. There may be some other things that don't work either, but that to me is the biggest.
Just to clarify, the license for RSO is free and fairly painless to acquire.
Russell Drown0 -
I created recently a LAN connection with an unlicensed RSO 5.9.2038. There may be a message box telling you that a service port connection is needed. Creating a robot view with LAN connection succeeded anyway...0
