IO Signals and pick events
Hi!
I've kind of solved the problem with the VC so far... i think so, at least.
But now, I am not capable of make pick events!
I've configured the event table (attach with do1=1, dettach with do1=0) and I've edited the main program with programmaker, inserting set do1 and reset do1 instructions.
When i want to play the procedure, it states that "do1" is undefined or something like that. It exactly says:  "Task MAIN: Reference to unknown entire data do1"
I've also taken a look into IO simulator, but it seems that no signal is active! (they are all in grey colour)
I'm programming IRB2400_16_M2000 and IRB2400_m94.
Thank you in advance.
Victor - En essayant!!
