Connect 2 IRC5 controlers DeviceNet
joaof
I need know if its possible connect 2 controlers IRC5 with DeviceNet, I need change values in a controler IRC5 and this values they are send by another controler IRC5, The Adress deviceNet of the controlers are the same by default, it is possible change the Adress of a DeviceNet controler IRC5?
Thanks,
Joao Fidalgo
Yes it is possible, see the attached document for more information.
2007-08-02_233806_devicenet.zip
You change the master address of a DNET board in RSO under IO>Bus>DeviceNetX>DeviceNet Master Address.
RussD2007-8-2 23:39:33Russell Drown0 -
Hi RussD,
Thanks for your help!
Tomorow I will make that experience!
Joao Fidalgo
Hi RussD,
Now it works!
Thanks!
Joao Fidalgo
