I loose my wobj data.
Klaus
I have notes that sometimes when i make a wobj unvisible it loose its data. All wogj data is then 0,0,0, and i have to sync to station to get the original position.
Is there a bug?
i use 5.09.2189.166
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Hi Klaus,
We are not aware of such a problem. I would very much appreciate if you can help us find a way to reproduce the problem.
The function for making the wobj invisible should be independent of the underlying data model and it is not obvious to me how the 'Visible' property affects the data of the workobject. Is there maybe some other operation that causes the workobject to be reset?
Kind regards,
ABB0
