Problem with IRB4400 S4C+
Hello,<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I'm having a problem with a IRB4400 2000 s4c+ controller.
It is been for years now that modules are added to a existing program. Last time after changing a program (adding a module) by a network connection, and then loading the program into the active memory, I got this message:
MCO:PGMLNK.C 3451
20311 Enable Open
10014 System error Status
I had to cut off the power, so he has done a P start, en had to do a restore of the previous backup.
I thought that we were running out of const robtargets, so I deleted the ones that were not used. After trying again, it worked, but when you reload it once more, I get this error again.
Can somebody help me with this problem.
Q
  • I'm having a problem with a IRB1400.
    error 20311
    status active when enable from I/O computer open
    20311 enable 1 open
    10014 system failure state
    20076 not allowed command
    10005 program stopped
  • Please add a Backup so i can see your configuration .... (add Log file)<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
    Enable 1 open,  can bee open by a lot of reson.
    "Panel board" and the "conector board" are runing a internal can bus, from the I/O-computer.
    I think "Enable 1" is runing through all these components..
    Check electrical drawings can give a hint!
    Check errors on  console port ..  (9600 boud) givs a hint on which part is failing in start upp mode.. (if you have lookt at the print out before)
    I think you can se status on "sys inputs" by typing   EIO_show  or eio_show in the terminal.
    A hint about "show" comand in a terminal window write   ->   lkup "show"
    and a list on show instruction will appear
    I forgot the KERNEL - C-code can also be a resson or a very hevy load on the I/O-buss if Poll rate is to low.
    vulpes_h2007-11-5 23:13:19
  • Hello...
    When did the error occur? Upgrade? runing program ? Reboting,restart ? Loading a backup? or configuration of multitasking? event_rutins?<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
    Will a i Start help ?
    a I-start will reboot a system to default configuration. (Program and motor-configuration I/O-configuration) will be reset to default...
    go to
    1. service ,
    2. restart
    3. then press 1,4,7
    and I-start will be present!
    If you still have problem after i-start, then it can be the robotware "c-code" fore the robot..
    If system ok  ...  load a working backup
    else..
    try to do a C-start
    1. service ,
    2. restart
    3. then press 1,3,4,6,7,9    C-start
    C-start will empty the robotware and the "system" include "system/Backup" folder copy backup from folder to PC by FTP.
    to save rapid code and configuration.... for loading later!
    Now you have to load a complete new "system" from "RobInstall" systembuilder for s4c+...
    If NOK now then it is a hardware problem...
  • Thank you very much for advice.
    Online Status: Offline
    Posted: 2007 November 04 at 17:20 | IP Logged
    Report Post
    Quote erik_izdenczy
    I'm having a problem with a IRB4400 M2000.
    error 71017
    71017: No activate signal
    DescriptionReason:
    - Missing activate signal for cross
