Virtual Controller Crash
neil
I have used RS 5.09 to set up a system from backup of a real IRC5 controller, which has a 4 axis gantry (X master, X slave, Y and Z).
When I try and start the system, the VC crashes. I have attached the error reports generated by this crash.
Any ideas why the VC is crashing for this system?
Thanks in advance
Thanks in advance
Hi Neil,
Since you are working with a gantry I would suspect that there is something in the motion configuration file that the VC cannot recognize. Unfortunately, the VC is very sensitive to errors in the configuration. In combination with a limited error handling this may give rise to the VC crashing. I would recommend you to get in touch with your ABB contact to work this issue out.
Kind regards,
ABB0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 300 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 336 IRC5
- 67 OmniCore
- 828 RAPID Programming
- 12 AppStudio
- 107 Collaborative Robots
