RS Online Fails to Start
neil
When I try to start RS Online, I get the following error:
Could not load file or assembly 'ABB.Robotics.RobotStudio.Online.Interop.AxSwcAppComponentLi b, Version=1.0.0.0, Culture=neutral, PublicKeyToke...
RobotStudioOnline.AppWindows
On clicking OK, RS Online crashes. This happens when I try to open RS Online independently and also through RobotStudio.
I am using RS Online 5.09.0166 and RS 5.09.2188. I also have RAB 5.09 installed on the same machine.
Does anybody know why RS Online will not start up?
Thanks in advance,
Neil
Thanks in advance,
Neil
Had the same problem half a year ago and did an uninstall of RSO and then installed it again and it was ok.
The file is probably missing in the assembly cache.Per Svensson
Consat Engineering0 -
Re-install of RSO seems to have corrected the problem.
Thanks,
Neil
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 300 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 336 IRC5
- 67 OmniCore
- 828 RAPID Programming
- 12 AppStudio
- 107 Collaborative Robots
