GUI
I need to make a aplication that have a PC with a software that communicate with a robot IRB140 IRC5, I need Know what is recomend software to make a application on PC like Visual Basic etc... If its possible what is the best mode to communicate whith robot RS232 etc?
Joao Fidalgo
  • You are pretty much limited to using Microsoft Visual Studio 2005, either Visual Basic or C#, with RAB 5.08 or higher. It would be much simpler to use the LAN port of the controller for connectivity, which requires the RobotWare option PC Interface. RAB is a Software Development Kit, so it does require prior experience with .Net programming to be used effectively.
    Russell Drown
