RSOnline 5.09 problem
AlexLu
My RobotStudio Online has a strange problem now. I could not open "File Management Window". There is no response after I clicked that tab.
I deleted the original RS Online, restarted the windows and then reinstalled RS Online. However, the problem keeps there.
Please help me to fix this issue.
See this post,
http://forums.robotstudio.com/forum_posts.asp?T ID=1186
especially the part about editing the settings file.
What most likely happened is that a path that is no longer valid got saved into your settings file, and it doesn't open the window when it can't find the path.
Russell Drown0
- 858 RAPID Programming
