10014 System Failed State
i have a problem whit controller irc, irb 4400 60 kg
when he extinguishes himself the controller appears these faults:
Operating Mode Conflict, No. de error: 20241
20195 System Data From Last Shutdown is Lost
20193 Robot Data Update Warninh
10045 System Restart
20573 Controller ID is Missing
i make a B-star and are they take off the faults
buy when he extinguishes himself the controller appears these faults
I need your help!!!!!!!
for try find solution!!!!!!!!!
Most likely being caused by intermittent fault in IPC power supply in Robot controller. (in our case anyway)0
- 40 AppStudio
