License error
I have previously made som small application with FlexPendant SDK 5.08. Now I've upgraded to 5.09 and I'm experimenting a little bit with PC SDK and the examples that are included in the documentation.
I startad with the network scanning application.
I'm working with three real robot controllers connected to my network. They Are all installed with RW 5.09 and have the option PC Interface.
In the PC I have just installed RAB 5.09 and also installed the license.
The error is a license error. I get this error when I doubleclick any of the controllers that are found in the controller list. The line that the execution stops at is as below:
Me.controller = ControllerFactory.CreateFrom(controllerinfo)
At that line it says that there is a license problem. I've included a picture of the error.
Does anyone know what might cause this?
/Per M
Have a look at the topic below and search "license" in the RAB user's guide, you must add a file called licenses.licx that references appropriate namespaces to your project.
Russell Drown0 -
Oops...
I should learn to study the manual carefully before asuming something is wrong.
Thanks for the hint.
/PerM
