Conveyor tracking, Queue Tracking Mode
jschoene
Hi guys,
we would like to use the DSQC 377A in Queue Tracking-Mode.
Reading the Robot ware conveyor tracking manual "3HAC16587-3 Revision D" (german version), I understand that you need to set the parameter
c1PosInJob = 1. In this case, we need to handle the WObj queue our selves. See manual page 87 (paragraph 9.1.2). (Notice c1PosInJob = 0 is the standard case, where the WObj queue is handled on the board - this is not used here.)
Example code from the manual for handling the WObj queue is given on page 90 and reads the following:
[code start]
SetDO c1PosInJobQ, 1;
CONNECT NewObj WITH NewObjOnConvey;
ISignalDI c1NewObjStrobe, high, NewObj;
TRAP NewObjOnConvey
ObjectPosition1 := GInput(c1Count1FromEnc);
ObjectPosition2 := GInput(c2Count2FromEnc);
RETURN;
ENDTRAP
TRAP TrackNewObj
SetGO c1Count1ToEnc, ObjectPosition1;
SetGO c1Count2ToEnc, ObjectPosition2;
WaitTime 0.05;
PulseDO c1CountToEncStr;
RETURN;
ENDTRAP
[code end]
This code does work if we pulse a DO, that is interrupt trapped by "TRAP TrackNewObj" and then use the instruction WaitWObj to actually connect to the WObj.
However, here is my question:
I do not fully understand, how we handle the case, if there is no work object yet.
Is it the right way to write a subroutine like (symbolic code)
[code start]
PROC GetWObj
if ( notEmpty(WObjQueue) ) then
# WObj available: connect
SetGO c1Count1ToEnc, WObjQueue.ObjectPosition1;
SetGO c1Count2ToEnc, WObjQueue.ObjectPosition2;
WaitTime 0.05;
WaitWObj WObj
else
# handle the case NO WObj available
end
[code end]
Summed up question:
Which is the professional way of implementing the queue tracking mode? Are there any fully runnable code examples available?
Any help is greatly appreciated.
Thanx,
Jan.
[code start]
TRAP NewObjOnConvey
RETURN;
ENDTRAP
TRAP TrackNewObj
WaitTime 0.05;
RETURN;
ENDTRAP
[code end]
[code start]
PROC GetWObj
WaitTime 0.05;
WaitWObj WObj
else
end
[code end]
Summed up question:
Thanx,
Jan.
