Problem with Sat format importing
    I got a large file with Iges format which i converted to Sat and then I tried to import in to  RS 4.0  the  cell is closing automatically with out giving any error or  any message
can any body give advice on this please
Tahnks
Thanks,
KiranKumar
  • Hi
    Try to open the ascis file in hoops 3d viewer to see if the acis file is correct. Download for free from www.spatial.com
    Per Svensson
    Consat Engineering
  • Thank you PerSvensson
    i tried,that file was not  correct  ok.
    Then i converted iges format in to *.jt by solidedge V18 and i tried opening in other softwares, it was opening with good resolution but the same file is not visible in robotstudio 4.0 the file name is visible in object list but nothing is seen in actual screen
     could u pls give some tips  about this
    Thanks,
    KiranKumar
